Charge nahi le rahe hai Not charging
Translation
Not charging
Translation
Not charging
@amanraj95479 you are not giving us a lot to work with here. 5 words is just not being very descriptive. We will need to know what exact model your Lenovo is. Also, tell us what you have already tried and checked to fix the no charging situation.
The general way to check it is by starting off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery. Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
Next you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see.
Of course, you may also have to consider replacing the battery. A depleted battery can no longer be charged. However, it should not prevent your computer from coming on, if it is connected to the AC adapter.
Let us know what you find out and provide us with more details so we can be more model specific.
Translation
@amanraj95479 aap hamen yahaan zyaada jaanakaaree nahin de rahe hain. 5 shabd zyaada jaanakaaree dene ke lie kaaphee nahin hain. hamen yah jaanana hoga ki aapaka lenovo ka kaun sa modal hai. saath hee, hamen yah bhee bataen ki chaarjing na hone kee samasya ko theek karane ke lie aapane pahale hee kya-kya koshish kee hai aur kya-kya chek kiya hai.
ise chek karane ka saamaany tareeka aasaan cheezon se shuroo karana hai. apane kampyootar se paavar kord ko anaplag karake kampyootar se paavar diskanekt karen. kampyootar se sabhee baaharee divais diskanekt karen. baitaree nikaalen. ab paavar batan ko lagabhag 30 sekand se 1 minat tak dabaakar rakhen. ach paavar edoptar ko phir se lagaen aur dekhen ki aapaka kampyootar koee sanket dikhaata hai ya nahin.
isake baad aapako apanee paavar saplaee chek karanee hogee. pakka karen ki usamen sahee voltej ho. yah chek karen ki kanektar mude hue to nahin hain, vagairah. apane laipatop ke dch-in jaik ko chek karen. pakka karen ki usamen koee jang, gandagee vagairah na ho jo use kaam karane se rok rahee ho. use kisee bhee gandagee vagairah se saaph karen, use saaph karane ke lie hava ke kuchh jhonkon ka istemaal karen. agar inamen se kuchh bhee kaam nahin karata hai, to ek emeetar len aur dekhen ki aapaka laipatop chaarjar se koee empeyar le raha hai ya nahin. usake baad, aapako yah chek karana hoga ki aapake madarabord ko paavar mil rahee hai ya nahin. isake lie, beshak, aapako ise kholana hoga. jo aap dekhate hain usakee kuchh achchhee tasveeren post karen. is tarah ham dekh paenge ki aap kya dekh rahe hain.
beshak, aapako baitaree badalane ke baare mein bhee sochana pad sakata hai. ek kharaab baitaree ab chaarj nahin ho sakatee. haalaanki, agar yah ach edoptar se kanekted hai, to isase aapake kampyootar ko chaaloo hone mein koee dikkat nahin honee chaahie.
hamen bataen ki aapako kya pata chalata hai aur hamen aur zyaada ditels den taaki ham modal ke hisaab se zyaada madad kar saken.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 10
All Time: 51
