LG washer Noise getting worse
LG WT4970CW washer noise has been getting worse over the last 3 months. Any idea what part is failing?
Is this happening only when it's agitating? There's a part at the bottom of the tub called the wash plate that may be coming unscrewed; the fix may be as simple as tightening it back up. Of course, it could also be stripped, which would be a bit more work to fix. I've uploaded the service manual for your washer here.
LG WT4970CW Service Manual - iFixit
Page 23 has information on removing what they call the pulsator, or wash wing as other sites refer to it. I'd take a look at that as a place to start, and check that the bolt underneath it that secures the tub is still tight.
Check that out and let us know what you find and we can go from there.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 191
1 Comment
sounds like your pump or drive motor is shot. I cant tell if its in the wash or drain cycle but if i had to guess Id say wash and I'd check that motor and the gears to the drum and if its the drain cycle pumps are usually one whole unit.
by JRock Share
