The Acer Chromebook 315, model number: CB315-3H/CB315-3HT, is a laptop released by Acer, used for basic online work by students, businesses, or anyone. This page provides repair guides, user and service manuals, reviews, and fixes for the Acer Chromebook 315.
Why won't my laptop show a display on the screen even though it's on?
I've been having trouble with my computer which is whenever I turn it on it shows the ChromeOS logo but then shuts off,if anyone could help id appreciate it.
Score 2
Add a comment
First, try doing a hard restart. When the chrome OS logo appears, try to interupt the system by pressing the power button again. If this doesn't work, then you may need to enter recovery mode. Here is a link that explains how to do so: https://support.google.com/chromebook/an...
1 Comment:
I did the recovery but it does the same thing when I turn the computer on,it just pops up for a second then it turns off.
by
Add a comment
On an ASUS Chromebook, this usually points to a power, software, or hardware issue. Common causes include a corrupted ChromeOS, battery/power fault, or display/firmware problem.
Try these fixes in order:
Hard reset: Turn it off → hold Refresh + Power for 10 seconds.
Charge check: Plug in the charger, wait 30 minutes, then try again.
Recovery mode: Press Esc + Refresh + Power. If it boots to recovery, reinstall ChromeOS using a recovery USB.
External display test: Connect to an external monitor to rule out a screen issue.
Power drain: Unplug charger, hold Power for 30 seconds, then retry.
If it still shuts off after the logo, it’s likely a battery, motherboard, or eMMC failure and needs professional repair.
Add a comment
Add your answer
Gavon Garcia will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 35
All Time: 93
