Released March 2017, model number 20JS0004US.
Why my laptop has a BIOS corruption?
My laptop keeps lighting up in loop. The keyboard goes on and off in repeat. The screen isn't lighting up. What procedures can I do to fix this.
Add a comment
1 Answer
Most Helpful Answer
Hi @jacksonking
Try a full power refresh and check if that resolves the problem.
a). Disconnect the charger from the laptop (if connected) and then open up the laptop and disconnect the main battery(s) from the motherboard and remove the RTC coin cell battery¹ from the motherboard
Here's the hardware maintenance manual for the laptop. Go to p.82-p.83 (p.88-p.89 of 121 pdf) in the manual to view the procedure to disconnect the battery(s) and then remove the RTC coin cell battery, respectively.
b). Press and hold the laptop's Power button for a full 30 seconds and then release it.
c). Reconnect the RTC battery, reconnect the main battery(s), reassemble the laptop and connect the charger.
d). Check if it turns on OK.
If it does then there may be a message stating that the time and date are incorrect. This is normal as the BIOS has been reset back to its factory default state by the above procedure. Once the date and time have been corrected, the message won't appear the next time the laptop is started. Also any user definable BIOS settings that were changed by you to suit whatever operating requirements you needed, will have to be change back again.
¹ When the RTC coin cell battery is removed from the laptop, measure its voltage. If it is <2.5V DC replace it. Search online for 02K7078 or 04W1642 to find suppliers that suit you best. If you don't have a DMM (digital multimeter) to measure the battery voltage then if the battery is > 4-5 years old, replace it anyway. This battery is used to maintain the BIOS settings once the laptop has been turned off and what happens is that when its voltage gets low, the BIOS can become corrupted, preventing the laptop from operating normally.
Score 1
Add a comment
Add your answer
Jackson King will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 41
