No backlight but 12v on f8400
After changing thermal paste and some clean keyboard with 96% isopropyl, Mac reboots ok. Totally working.
While doing reset smc just for a fresh restart, Macs turns off. After rebooting it, nothing changes.
Took it to a repair man and find out that, if lcd is connected Mac doesn't start completely (20v, green caps lock, apple logo but with led light pointed to screen, sometimes chime, keyboard backlight on, but only "esc"written on Touch Bar, if monitor plugged, nothing happen).
If lcd connector is disconnect!!!, Mac boots normally connected to a monitor and completely works.
No further technician help, so I was going by myself.
Started measuring dc while pc on connected to an external monitor (fully working).
Found 12,6 on side 1 of f8400, and same value on side 2 of it.
Continued checking voltage, but already on c8410 0v, same on al the big caps c846x/c847x (so no boosting up to the 46-55v...)
So I was going to check mosfet q8400 since c8410 was on 0v.
Started checking 6, after 5, after 1 (all at 0v) and once I touched the port 2 it has done a spark.
After that I was going to check port 4 and 3 of the mosfet, but the fuse f8400 is not giving continuity.
Pc still fully working if connected to external monitor.
What can I do?
Could the mosfet be the first cause of all the problems?
If can be useful I've checked r8401 and r8402 and they are as schematic, but I do not know how to continue and what can I do.
Thank you if you've read up to here and have a good day
P.s. I got a usb c multimeter but and would like to help you to know how is doing with the spark mosfet, but with the fuse interrupting the line I think it is not a good idea, or maybe it can?
Should I try to connect the lcd with the backlight line blocked by blown fuse and check if the old behaviors are still there? Or it is unnecessary?
Update (01/13/26)
Arghh...
Have I done a big mistake?
One of the two pad of the fuse come out with the solder
…is it solvable?
Update (01/13/26)
Here the piece that came out
Could be a good idea to try to attach it to the old fuse and the try to solder it to the pcb or is it a bad way?
There is sonething easier?
Update (01/14/26)
Thank you as always!
Here you re, that the best I can do with my lens, a microscope is coming…
Just today if needed, as arrived my dc power supply, if can be usefull;but, as you can imagine I ve never used it
Is it there any kind of measurement I can do without power?
Without the fuse I think I can inspect the backlight line alone?
3 Comments
@oldturkey03
Here the piece that came out[image|3964323]
by Bbq Lover
Not possible anymore, I ve loose the micro square…any solution?
Fusing al the 6 points with copper lines and use them as a base for the fuse?
by Bbq Lover
@bbqlover look like you lost the solder pad. Is there any chance you can post a better picture of what has happened? We can portably run a jumper wire to the pad.
by oldturkey03
