Shop the Holiday Gift Guide
Repair information for Samsung clothes dryers.
Samsung dryer (DV365ETBGWR/A3) blowing fuse
Samsung dryer model DV365ETBGWR/A3
Started not heating. Opened it up, found the heating element had a break in it, so replaced the heating element. Also cleaned out all lint, and the made sure the airflow to the outside was good and clean.
Second load, it stopped heating. Found the high temp fuse had failed. Replaced that. Tested ok. Put machine back together.
My wife says it worked for a few loads, not sure how many. Then stopped heating. checked the fuse, and it had blown again. Replaced all four pieces (three fuses and themostat). Completely cleaned everything. Even took fan out and cleaned it.
Tested before I put machine back together, ran fine. Element came on, heated, turned off, came back on. Sometime during first load, stopped heating. I havnt checked yet, but I am assuming the same fuse is blown.
What next, the control panel? Sounds like a short in the system or something, maybe I am missing something else?
Add a comment
1 Answer
Most Helpful Answer
Hi @jonwhiting
Before replacing the fuse, disconnect the power to the dryer and then use a DMM's Ohmmeter function and measure between a heater terminal and the chassis of the dryer (clean, bright shiny metal point) to make sure that the heater wiring is not framing to the chassis Earth e.g. abraded wire rubbing on chassis or crimped wire. The meter should show OL or infinite Ohms and not 0.00 Ohms.
If it indicates a connection between the heater and the chassis then you may have to trace the heater wires to see where they run back to the control board, for any obvious damage.
Score 2
3 Comments:
I left everything as is, just removed the control panel at the top, and the front panel (to reach the heating element section. One probe on lead into heating element, touched other probe all over frame. Always OL. Never went to 0.00.
Also checked the moisture sensors to see if somehow they were touching. Nothing until a wet rag was touched.
Took the heating unit out, and yes, the fuse was blow.
Two things I did find while showing my son what I was doing.
1) Somehow the cover for the light inside was missing (probably because I still cant find it)
2) one screw was missing that connected the box the control board is housed into the metal support that goes side to side under the control panel
Maybe there is enough moisture or clothing hitting the light area that it is causing a short? Im going to leave the light completely unplugged and try a new fuse.
And without that screw, the box is not touching the metal support panel. Maybe that is where it gets some sort of ground.
by Share
Swapped the fuse, tested to make sure it worked. Put everything back together and tested things again, and it all look good. Turned it on, held the door switch closed, and pressed store. No heat, no heat element. Appears like it had popped the fuse again, this time, right away
by Share
Hi @jonwhiting
I assume that it started OK, just no heat?
If it didn't start I wonder if it has nothing to do with the heater now but it may be something else e.g. motor winding perhaps.
This is the closest that I could find by way of a service manual for the dryer, so hopefully it may be of some help.
The first 9 (out of 11) characters in the model number are the same so hopefully there isn't too much of a difference between it and your model.
On p.4 it shows how to check the motor and on p.10 there's a wiring diagram
by Share
Add a comment
Add your answer
Jon Whiting will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 44
All Time: 247
