The Porsche Cayman and Boxster are mid-engine, two-seater sports cars produced by Porsche. This is a repair and support guide the fourth generation of Porsche Cayman and Boxster: the 718/982 Series.
check front right dipped headlight
my 2014 porsche 981 718 cayman check front right dipped headlight appear on my dash. how can i fix this myself and what is the correct light i need to replace? thank you 🙏🏼so much.
Add a comment
Chosen Solution
@speedbumpla looks like you need to remove the headlight to get to the bulb. Here are the instruction for the 2013 2016 Porsche Cayman Boxster Base S GT4 981 Headlight Removal As for which bulb, I would wait until you have the old one removed then get the replacement. That way you know that it is the right model for sure. Those should be Philips - Diamond Vision H7 Halogen HID Bulbs but again, wait until you have the old one out. If you need more or different information you can now get the complete workshop manual from this page Porsche 718/982 Series under the Documents header
Score 1
Add a comment
You should check whether your headlights are on normally.
Add a comment
Add your answer
speedbumpLA will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 15
All Time: 111
