Canon imageCLASS MF4150 – Paper jam deep inside, how do I open this se
I have a Canon imageCLASS MF4150 monochrome laser printer. A sheet of paper got jammed deep inside the printer, and when I tried to pull it out gently, part of the paper tore and remains stuck inside, while the rest was pulled out.
I powered off and unplugged the printer, then tried opening both the front cover (toner area) and the rear cover. However, only the outer covers opened, and I was not able to open the printer completely or access the internal jammed section.
The remaining paper is not clearly reachable from either the front or the back, and I am not sure which internal latch, lever, or section needs to be opened next to remove it safely. I don’t want to force anything and risk damaging the rollers or the fuser.
Add a comment
