Camera Wont turn on?
The camera started by having glitchs in which it would shut off while i was taking a picture now the camera wont turn on. It has a fully charged battery. what can i do?
Isis, here is my answer to a similar question "time to take it apart and check the battery connections. Make sure they are all in good working order. Check the bottom of the battery door, make sure that it pushes the battery so as to make connection with the battery connectors. Of course, make sure that your connectors are not corroded. Here is what the service manual suggest:
"Problem (when an error code is not displayed)
The power of the camera does not turn on.
Defect position
OPERATION FPC ASSM’Y
MAIN PCB ASSM’Y/
BATTERY COVER
FUSE (MAIN PCB ASSM’Y)
Reference
BATTERY COVER deformation.
POWER SW cannot be turned on.
POWER BUTTON cannot be turned on.
BATTERY/CARD SLOT OPEN DETECT SW cannot be turned on.
and more here:"
If the Power cannot be Turned On
Procedure/Check point
1.Remove the front cover and the rear cover.
2.Check whether the BATTERY COVER open/close detection switch on the MAIN PCB ASSM’Y is broken
Of course you also want to make sure that the battery flex cable is in good working order and that the connector is not corroded, broken, or disconnected. I attached images for the fuse location as well as the battery cover open detect switch. Hope this helps, good luck.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,020
