The Logitech G9/G9X is a laser gaming mouse. They are programmable and feature precision grips. Model numbers are: G9: M/N M-UAJ132 and G9x: M/N M-U0006.
I am trying to find the flexible ribbon connector for my Logitech G9X
I am trying to find the flexible ribbon connector for my Logitech G9X part number PN 210-000020. I can not find it anywhere. Anyone know a source to get this part?
Add a comment
1 Answer
Hi @carlburkhart!
You're right - that specific PN 210-000020 is nearly impossible to find as a standalone part. For older Hardware it should be just a standard FFC (Flat Flexible Cable).
According to my Information, it should be a ribbon cable for the DPI buttons, side buttons and RGB flex on the G9X.
Specifications you may need:
  • Pitch: 0.5mm (most common in gaming mice)​
  • Pins: Count the conductors on your cable (probably 6-12 pins)
  • Type: Same-side or opposite-side contacts (check your connector orientation)
  • Length: Measure your old cable
Where to buy generic replacements:
  1. Mouser/Farnell - Professional distributors with 0.5mm pitch FFC cables in various pin counts​
  2. AliExpress - Search for "FFC 0.5mm pitch [X]pin" where X is your pin count. Usually $1-3 for multiple cables​
  3. Bananas Gaming (DE) - Specializes in mouse FFC cables​
  4. eBay - Generic FFC/FPC cables in standard configurations
Pro tip: As long as the pitch (0.5mm), pin count, and contact orientation match, any generic FFC will work. The cable length doesn't have to be exact - you can route excess cable inside the mouse.
Hope this helps! Let me know if you need help identifying the exact specs.
Best Wishes
Marvin
Add a comment
Add your answer
Carl Burkhart will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 39
