Model A1318 / 32 or 64 GB capacity
394 Questions View all
Why isn't my iPod touch connecting to Itunes or any computer?
My Ipod will not turn on and I have plugged it in for hours and a pop up will come up and show me a adapter with a arrow to itunes. So when I plug it in, it doesnt reconize my ipod. How do i fix that?
Add a comment
1 Answer
Chosen Solution
meg, try to charge it on a AC adapter first. If it does not charge, start by cleaning the dock connector. As always, check for any obvious damage, like broken, bend, or corroded pins. Also clean it with some isopropyl alcohol and/ or a couple of puffs of compressed air. Make sure that you have a good working cable. If all that checks out okay, I would start with replacing the battery. Use this guide to change it. Not an easy job, but doable. When you have it apart to change the battery, also check for any obvious damage, like broken/missing components and corrosion. Reevaluate after for any further damage. BTW your computer may not recognize it because of a dead battery, and the USB port not supplying enough power. Hope this helps, good luck.
Score 2
Add a comment
Add your answer
meg will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 517
