Can I do a one-for-one HD swap between MacBooks?
Just installed a Seagate 7200 RPM 500GB SATA-SSD hybrid drive in my 2009 Santa Rosa Macbook. Restored my data and OS (OSX Lion) from the Time Capsule, and it was a very simple and trouble free process. Thanks, iFixit!
I'm now interested in installing that drive in my wife's mid-2010 MacBook Pro completely as-is, and putting her OEM 320GB drive in the older MB. Both machines are running the same OSX version, but obviously they're quite different under the hood. Is doing a one-for-one swap with these drives as simple as plug-and-play, or is there something more I need to consider?
Thanks for the advice/tips!
Add a comment
1 Answer
Chosen Solution
You should be able to make the switch with no problems. You will need a minimum of 2 GB of RAM in the older machine.
Score 3
Comments:
So the machine should boot up and, for all intents and purposes, look/act/feel in the MBP just as it did in the MB? Seems too good to be true! Will report back with the results. Thanks for the confidence!
by
Add a comment
Add your answer
biegerd will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 618
