Released 2020 with Snapdragon 720G SOC Sold in India as the Note 9 Pro Max
Why is it not showing data transfer on my laptop only charging?
It is not showing on my laptop for data transfer only charging
Add a comment
1 Answer
“Great question 👌, and the reason usually comes down to the type of cable or USB port being used. Some cables or ports support charging only and do not transfer data. Here are the details:”
🔌 Possible Causes
  • USB charging-only cable: Some cables are designed to deliver power only, without the wires needed for data transfer.
  • Dedicated charging USB port: Some laptops have USB ports dedicated to fast charging (often marked with a battery or lightning symbol), and these do not transfer data.
  • Phone or device settings: When connecting your phone to the laptop, you may need to select “File Transfer” or “MTP” mode instead of “Charging only.”
  • Drivers: Sometimes you need to install the proper drivers (such as Android or iPhone drivers) for the data transfer option to appear.
🛠️ Practical Solutions
  • Use an original or certified cable that supports data transfer (these are usually slightly thicker than charging-only cables).
  • Try another USB port on the laptop (preferably USB 3.0 or 3.1).
  • Check your phone’s settings after connecting and select “File Transfer.”
  • If the device still doesn’t appear, install or update the necessary drivers.
🔎 To be sure: would you like me to show you illustrative images that highlight the difference between a charging-only cable and a data-transfer cable?
Add a comment
Add your answer
Shadreck swira will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 21
All Time: 189
