Repair information for the Google Pixel 4a. Released on August 20th, 2020. Model number: GA02099-US.
My phone dropped into water
1 Comment
Did you dry it off quickly?
by
Add a comment
1 Answer
Most Helpful Answer
Hi @mosesmhewa
The phone does not have a waterproof rating so check if the LDI (liquid damage indicator) shows whether water has entered the phone or not.
Here's a link that shows where to look. Scroll down and select Liquid or Corrosion evidence
If the LDI indicates that water has entered the phone do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit Google Pixel 4a repair guide, that may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Score 2
Add a comment
Add your answer
Moses Mhewa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 40
