The Whirlpool WRS588FIHZ is a side-by-side stainless steel refrigerator with a total capacity of 21.7 cu. ft., featuring frameless glass shelves, LED lighting, adjustable gallon door bins, and a factory-installed ice maker. It is equipped with electronic temperature controls, temperature alarm, automatic defrost, and is ADA compliant.
Why is my ice dispenser intermittent while in use
Ice and water dispensing cuts in and out during use
1 Comment:
Hi @michaelbon86659
What is the full model number of the refrigerator?
Asking as there are 3 models beginning with WRS588FIHZ i.e. WRS588FIHZ00, WRS588FIHZ04 & WRS588FIHZ06 and they're all slightly different.
by
Add a comment
1 Answer
Change your water filter inside the fridge the model number is usuallly on the filter itself . If you have hard water the filters should be replaced on a three to 6 month interval . If you connect the water feed from a Reverse Osmosis you can save on filters by using a blank in fridge it acts like a bypass.
Add a comment
Add your answer
Michael Bonnecaze will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 19
