Repair and disassembly information for the Nokia G310 5G Android smartphone, released in August 2023. Identified by model number TA-1573.
Trouble connecting Audien ion pro hearing aids
Connection problem connecting to Audien Ion Pro hearing aids
1 Comment
Have had Audien staff help with troubleshooting and can’t connect. “Should” be compatible but can’t get it to work.
by
Add a comment
1 Answer
Most Helpful Answer
@stevenorri73362
Doesn't seem to mention it in the User manual for the hearing aids, but have you tried using the app in the phone to connect to the hearing aids?
try switching the hearing aids off and with the Bluetooth turned on in the phone, switch the hearing aids back on again and check if they appear in the phone's BT available devices menu list or if they pair with the phone.
I know of two different makes of hearing aids (not your make though) where the Bluetooth in the hearing aid is only enabled for a couple of minutes after the hearing aids have been turned on. If they aren't paired with a Bluetooth device within that time the Bluetooth is switched off. Once they have paired they will stay connected.
Can you pair the hearing aids to another Bluetooth enabled phone OK?
Score 1
Add a comment
Add your answer
Steve Norris will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 28
All Time: 130
