Repair guides, disassembly, and troubleshooting information for the HP EliteBook 840 G8, an Intel business laptop released by HP in December of 2020.
laptop fan seems to be on after power down
after i have used power button to shut down the laptop, when i carry in my back pack i notice when bag is shaken i can hear what seems to be the laptop fan running. i then have to press down on power button again for a few seconds to power down again or start up the system and shut it down again
Add a comment
Most Helpful Answer
If the laptop was run hard (or for a long time, think hours), the HP machines will run the fan for a little bit after shutdown - usually 3-5 minutes to avoid thermal shock to the BGA chips under the CPU die. It doesn't do it if the chip isn't hot, but if the laptop was on for a long time that's normal. What isn't normal is if it's on for 20-30 minutes. Before you pack it, let it run for 5-10 minutes outside of your bag and it will typically shut off if the machine is just cooling things down. It's honestly more prevalent in Intel models and GPU equipped models over a lot of AMD machines, but even AMD models do it.
If it is on for 20-30 minutes, pull both the CMOS battery and primary battery to reset the BIOS and see if it continues. Use these guides to do it:
HP Elitebook 840 G8 Battery Replacement (Revivekit)
HP Elitebook 840 G8 RTC Battery Replacement
If it still happens, press ESC and then F2 -- run the system board test. If you just have the UEFI version it is limited but unless you secure erased a surplus PC it will probably still be there. Good thing is HP makes it available to reinstall: https://support.hp.com/us-en/help/hp-pc-...
HP Elitebook 840 G8 Battery Image
Guide
Difficulty:
Moderate
15 - 20 minutes
HP Elitebook 840 G8 RTC Battery Image
Guide
Difficulty:
Moderate
15 - 20 minutes
Score 2
Add a comment
Well I will suggest you to checkout the following video: https://www.youtube.com/watch?v=lX69uFGH...
Add a comment
Add your answer
dafe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 16
All Time: 111
