Information for the second generation Ford Expedition, from 2003-2006.
Steering Rack and Pinion rebuild 2004 Expedition 4x4 EB 5.4
Just seeking some wisdom from some legends on how (as the title states) to rebuild a Steering rack and pinion? I haven't done before and not afraid to give it a go. If some legend is able to put up a kind of Tutorial of sorts this would be legendary.
Score 1
Add a comment
1 Answer
Chosen Solution
@bromeo60583 not sure what's going on with your steering rack but start of with the Ford Expedition Navigator Steering chapter for your Expedition. As for the actual rebuild, this gets trickier. Ford does not build it's own rack and pinion but get's most (not all ;-) from Detroit Axle. The same company also supplies the rack and pinion for Toyota. Check the Power Steering Rack Overhaul Procedure for those. It's most likely not the identical rack but essentially it will be worked on the same, meaning you will have to adjust the steps to your steering rack
Score 2
3 Comments:
This is a start and thank you mate! Well about 2 months ago the rack started leaking from the "outlet" that connects up to the 2 pressure lines. Bugger of a thing to get to but sorted it out. stopped leaking. Now it seems like its leaking somewhere else but within the same vicinity. Sometimes it leaks about 20-50ml depended on the drive and sometimes it doesn't. So, my train of thought is "stuff it" I will pull the whole thing out and get a rebuild kit off rockauto and swap everything out and have a bit of a nosey.
by
Again @oldturkey03 , appreciated mate!
by
@bromeo60583 and that "get a rebuild kit off rockauto and swap everything out " is the way to do it. Take some good pictures and document things well while you work on it. I am sure that there are lots of people on here who love to see what all is involved. Best of luck to you.
by
Add a comment
Add your answer
Bromeo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 26
All Time: 126
