Repair documentation and service information for Hisense televisions.
Why is my hisense 50 inches TV not displaying but can hear the sounds
Add a comment
1 Answer
Most Helpful Answer
@michael48038 there are a few reasons why this could be. Commonly on Hisense TV's it's the backlights. Further reasons are a bad power supply, bad t-con (depends on the model) board and even a bad LCD panel.
Check the backlight first. Turn the TV to a channel where you can hear the sound. Next, use a flashlight and shine the beam at an angle against the screen. Do that in a darkened room. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed.
If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damaged components. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Adding images to an existing question for that so we can see what you see. It is possible that this is either a power board or a T-con board issue.
We will need to know your exact model.
Score 1
Add a comment
Add your answer
Michael will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 20
