The second generation of Citroen's supermini car was produced between 2009 and 2016.
My Citroen is showing oil sensor fault. I cannot locate the sensor.
My citroen ds3 is showing oil sensor fault, but I cannot find where the sensor is located
Score 1
Add a comment
1 Answer
Most Helpful Answer
@jay67485 it would help if you can tell us the actual error code. That way we would know if you are referring to the engine oil pressure sensor or the oil level sensor. For example, the oil level sensor for the 1st gen C3 is located in the engine block just above the oil pan. The oil pressure sensor in on the oil filter housing.
It is also important to notice that your Citroen, if it has an automatic transmission, has an oil pressure sensor as well. We need to know exactly which engine your Citroen has.
Score 1
Add a comment
Add your answer
Jay will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 9
Past 30 Days: 38
All Time: 382
