Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1963 Questions View all
Question Closed
Wet iPhone only connects to iTunes on recovery?
I accidentally wet my iPhone. I didn't turn it on since then. So far I:
  • Put iPhone in rice (opened iPhone) - 24 hours
  • Put motherboard in alcohol, then put it in rice - 24 hours
After each attempt, the iPhone connects to iTunes in recovery mode, blank screen. I used TinyUmbrella and clicked, "Fix Recovery". The only thing thats different is that, on the screen, the back lit has texts on it (like when you first jailbreak an iPhone).
What are my options?
Add a comment
Android Fix Kits
A new screen or battery is one kit away.
Shop Now
Android Fix Kits
Shop Now
1 Answer
Try to restore it how it is.
Try to restore it in DFU mode. (10 seconds power and home and continue to hold home while connected via usb)
Try to restore it in recovery mode.(10 seconds power and home and continue to hold home while not connected)
post your error codes if you get any.
Comments:
Error 1600. I also got 1602 before.
Other times, iTunes crashes while it says, "Preparing iPhone..."
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,065
