Released in 2012. A mirrorless digital camera with an interchangeable lens and integrated Wi-Fi allows users to share photos directly with smartphones and tablets. Manufactured by Sony.
Shutter stuck after triggering, no power going to shutter motor
I fully disassembled my NEX-5R to fix the lens interface and when I put it back together the shutter failed. The front curtain closes but then the motor that is supposed to wind it back does not run. I tested the motor with external power and it spins normally so the issue is that the main board is not sending any power to the motor, instead it just closes the front curtain then gives a camera error. Why is this happening?
Add a comment
1 Answer
Chosen Solution
After checking signals and voltages on the board it turned out to be a blown fuse. Not sure how I managed to blow it but it certainly was blown upon measurement with a multimeter. The shutter motor fuse is the uppermost component in the circled area:
After shorting its terminals with some coil wire the shutter started working again.
Add a comment
Add your answer
Tooniis will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 18
All Time: 211
