Repair and disassembly information for Samsung's Galaxy A22 Android smartphone, released in July 2021.
My samsung is bloated speaker and charging port not working!
What the problem and what should i fix and how much i hope i get notice because i only have 18% thank you so much!
2 Comments
The battery is BAD and MUST be replaced As soon as possible, stop trying to charge it, you may end up with it causing more damage to the phone.
by
@danj OMG! Thank you so much!! THIS HELP ME VERY WELL!
by
Add a comment
1 Answer
Chosen Solution
By "bloated" if you mean is is 'swollen' the battery is bad and you should replace it as soon as possible, continuing to use it with a swollen battery may cause severe damage to the phone. The problem with the charging port is probably that the battery's internal resistance has gone up due to bad cells and if you keep charging it or using it, it may even catch fire.
Probably not, but it has happened. Sorry, get a new battery and dispose of the old one properly. You can probably leave it with the shop where you buy a new one. The speaker might have been damaged by the bad battery, hopefully not.
Good Luck.
Score 1
1 Comment:
@Juan Garcia Thank you so much!
by
Add a comment
Add your answer
Marc Dela Cruz will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 23
All Time: 182
