Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Questions View all
Liquid spill: 6500RPM Fan speed, webcam/AirPort card not recognized
I have a MacBook Pro 13" A1278 with liquid damage somehow still affecting it in a weird way, although the liquid (redwine) did not enter through the keyboard, as it was covered by a rubber-coating I have. The liquid was on the keyboard, but went towards the screen and down back into the area where the air comes out.
The machine have had the DC-In board replaced, which solved the charging problem it had. In addition it has been taken apart twice and cleaned completely.
Problem:
The fan runs at high speed at 45 degrees celsius, and AirPort card and webcam is not recognized - HOWEVER, if I power down, remove the bottom panel and power up again, everything is working fine!
Question:
What causes this to happen? I have tried to cover the entire inside of the backpanel with tape so nothing from the logic board touches the bottom panel, but it's the same. I also tried placing the bottom panel loosely on the back whilst having the laptop standing on the side; this works unless I press is up against the bottom to fit it correctly.
Any suggestions?
Score -1
Add a comment
1 Answer
Chosen Solution
Sounds like something in the bottom is shorting out your board. This could be a dent, screws placed in the wrong holes, something extending down from the underside that shouldn't. Check your placement of the three longer screws found in this guide: MacBook Pro 13" Unibody Mid 2010 Lower Case Replacement
Score 3
Add a comment
Add your answer
jakobnord will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 560
