Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
840 Questions View all
Why won't my iPod work?
I had replaced the battery cause it was old. Since then the iPod doesn't charge at the computer but turns when plugged into the wall. Message says to connect to a computer to resolve issue. But it won't turn on when plugged into the computer. I had changed the motherboard. Same issue. What else could it be? i swapped everything i could think of that would affect the power and no dice.
Add a comment
Chosen Solution
Hi,
the battery to low message sounds to me like a bad hard drive.
Add a comment
Did you already try to use a different cable, maybe yours is damaged?
Add a comment
As asked by Crisb try a different iPod chord. If that doesn’t work try hooking it to a friend’s pc. If it works then you may have a USB problem. Are you using Mac or windows?
Comments:
I have multiple cords and i have a pc i tried it on as well. just sits and doesn't take enough charge to be recognized by the computer. It has the "battery too low" and that's as far as i get. I'm starting to think maybe the hard drive or the battery is shot again...
by
Add a comment
Add your answer
martyz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 627
