The current line of iPod Nanos comprises seven different generations.
1137 Questions View all
My iPod is heating very very high when connected to charger
when connected to charger its hetting very much and not charging
Add a comment
1 Answer
Chosen Solution
saravananmk7, start be cleaning your dock connector, make sure that there are not broken, bend or corroded pins. Clean is with some isopropyl alcohol. Change your battery, since it is possible that it overheats due to a bad battery circuit. If nothing else, it will provide you with a known good starting point. The guides for the Nano are here. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
saravananmk7 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 248
