My laptop cannot be charged and cannot be turned on when I want to cha
My laptop cannot be charged and cannot be turned on when I want to charge it. No lights on this laptop.
@adamdaniel919 sounds like you are saying your laptop does not have any sign of life.
Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
Next you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc., use a few puffs of air to clean it out. If none of this works, get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Since iFixit does not yet have a guide for this, use something like this video Post Some good pictures of what you see. That way we can see what you see.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 33
All Time: 164
