The Xiaomi Redmi 9C is a low-budget smartphone by Xiaomi released June 2020. It has a 6.53" IPS LCD display, a 13 MP main camera, a 5000 mAh battery, and runs on a Helio G35.
Why is my Redmi phone stuck on the logo?
Sorry, why did my Redmi 9C hang, then I tried to restart it but it wouldn't turn on and was stuck on the logo, even though the battery was in good condition? Thank you
Add a comment
1 Answer
@hisninamrina that is usually caused by your phone not being able to "read" the firmware. Normally we do not deal with firmware/software or password issues on here. Since it is possible that your issue is hardware related, you will need to first rule out a software issue. For that, try a force restart:
  • Press and hold the Power button and Volume Up button simultaneously.
  • Continue holding them for 10-15 seconds or until the phone vibrates or the Mi logo appears, then release.
If that does not work you probably will have to try a factory reset. Careful with that since it will delete all of your files (music, pictures, SMS, contacts etc.) You will also need the email address/username as well as the password you've used when you first setup the phone. Without it, you wont be able to access (sort off ;-) the phone after the reset.
erase all your data.
  • With the phone off, press and hold the Power and Volume Up buttons.
  • Release when the Mi logo appears to enter recovery mode.
  • Use the volume buttons to select "Wipe data" and the power button to confirm.
  • Select "Wipe All Data" and then "Confirm".
  • After the wipe is complete, select "Reboot" to restart the phone.
Let us know what you find out.
Add a comment
Add your answer
Hisnin Amrina will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 35
All Time: 129
