Find repair and more information about the Maytag MFI2665XE*, a bottom freezer style refrigerator without an in-door ice dispenser, manufactured in 2010 by Whirlpool Corporation. This page covers information for model numbers matching the pattern MFI2665XE*.
Fridge and freezer are not cooling.
Fridge and freezer stoped cooling. You could hear the fridge was clicking. I changed out the capacitor and the compressor start relay. The fridge then could be heard turning on. The coils were cleaned and vacuumed and I also checked the coils and fan inside the freezer. Coils were clear and fan was working. Only thing left is the thermostat.
Is there anything else I should be checking???
Add a comment
1 Answer
Most Helpful Answer
With access to cleaning and replacing suspected parts, you should be able to do a simple test using your hand as a crude thermometer; feeling the compressor discharge coils and freezer compartment for hot and cold refrigerant. The basic refrigeration cycle; compressor discharges high pressure refrigerant that's hot, cooled as it travels thru the condensor coils, turns gas to liquid, discharges thru a tiny capillary tube where liquid refrigerant is allowed to expand and return to its gaseous state while absorbing heat from freezer coils, returns from vacuum generated from the compressor and repeat the cycle. If the compressor is running, you should feel its output tube going to the condenser coils as hot. The freezer coils, under the floor (top freezer) or rear (side by side) with fan moving air for circulation, should be cold. If both sections are lukewarm, either the system leaked refrigerant or the compressor failed internally. In either scenario and the compressor is running, replacing the compressor, filter/drier and refrigerant requires professional repairs unless you have skills and equipment to make repairs.
Score 2
Add a comment
Add your answer
Masomase36 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 55
