iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
369 Questions View all
12.7 mm SATA Optical Bay SATA Hard Drive Enclosure?
Id like to replace the Superdrive with an optical bay adapter but previous answers only lead to a list of non-compatible adapters. Can someone please provide a link or part number for the actual product i need.
From what i can read this is NOT the compatible: Product code: IF107-081-1
iMac Intel 27" EMC 2309 Late 2009 Core i5 2.66GHz
Please help
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
Are you trying to swap out the super drive and mount a second HD or a SSD in its place? Can you tell us which and it's size.
If you look at the iFixIt Guide page for this system you'll see the player is held in a plastic tray by four screws if you remove the player you can mount the full sized HD directly or HD or SSD on to this frame by using a 3 1/2" or 2 1/2" adapter frame HD/SSD frame kits. You still have the I/O and power connections to deal with.
Add a comment
Add your answer
ChubbsTheMacGuy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 944
