1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
154 Questions View all
Should I remove SSD in my situation?
Hi there.
I want replace my broken screen and first of all I should remove the display. So I stopped at this step: MacBook Air 11" Mid 2011 Display Assembly Replacement cause I have broken thread of screw. Its bad I know but I do not want replace SSD. So my question: Can I continue this guide without remove of SSD?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
It appears to me that you can continue with the guide without removing the card. Just be sure to observe ESD protocols when working on your machine, read through this before working on your machine: Electrostatic discharge (ESD) control
Score 2
Comments:
Thanks a lot. But I found problem with this: in next steps I should remove cooler but I can't do that without remove SSD, because screw hidden under SSD :)
by
Add a comment
Add your answer
Maxim will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 913
