Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7 Processors
515 Questions View all
MBP makes strange noise (left fan?)
Hi community!
Since today my MBP (mid 2010) makes very strange noise. It comes from anywhere near the tabulator key. I just opened my MBP, under the tabulator key is the left fan.
I made a short video to demonstrate the noise:
http://www.youtube.com/watch?v=Bgee3A47Q...
Please help me, I have important examinations in two weeks, my laptop is very important for me! :-/
Greets
Klaus
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Thanks for the video. Yes this sounds like something is pressing against the fan. I would first check to see if the attachment cable is getting caught and pressed into it. That failing I would remove the fan to see what could be pressing against it. As I always recommend, users should always use an external hard drive for Time Machine backup. These things are cheap now, under a hundred dollars and can save you a lot of greif if you ever lose your hard drive or, God forbid, your Book. Here's how to do it: MacBook Pro 15" Unibody Mid 2010 Left Fan Replacement
Score 3
Comments:
thank you, i give that a try!
by
does it work? i have the same issue.
by
Add a comment
Add your answer
Klaus Hiesmayr will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 11
Past 30 Days: 25
All Time: 3,280
