If I had read the iFixit guide before replacing the display, maybe...
Hello! Unfortunately, I read this guide too late and replaced the display without performing the procedure that isolates the battery connector; I essentially removed the display while it was powered on. Everything else was done perfectly without any damage, but now the display won't light up. The Apple icon doesn't appear, but if I repeatedly press the power button, I can briefly see that the iPad is on. With very low light intensity, I can read the time at the top of the display.
I've done the forced restart several times, but nothing changes: no Apple icon turns on, the display is black, but, as described above, the iPad is on.
Can you help me figure out if I've permanently damaged the device or if I'm just missing something that's causing this?
Thank you very much.
Mario
1 Comment
Unfortunately, I tried two screens with the same procedure without disconnecting, or rather isolating, the battery contacts. The two screens behaved the same way: you can see short flashes, and then for a second the home page, but only when you press the power button repeatedly. I will try your advice of using a light bulb to create backlighting. Thanks so much for your help, I'll let you know how things go.
by Mario
