1975-2011 (The picture is of a 2008 grand marquis)
Milky dipstick how to fix
I can’t tell what is causing the oil n coolant to mix i doing see no smoke from tail pipes
1 Comment
@rickyperales what is the exact year and engine size for your Mercury?
by
Add a comment
1 Answer
Most Helpful Answer
You may have a leak in your oil cooler. The tailpipe white smoke is usually from a blown head gasket. You should check your coolant to see if there is any oil in it, and to check the coolant level. Change your oil right away, too.
Score 2
Add a comment
Add your answer
Ricky Perales will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 27
All Time: 104
