Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Questions View all
What Part Do I Change Once The iPhone 4s Gets Wet?
My phone decided to take a swim! yeah I know right? I've been letting it sit in rice for more than 24 hours it still hasn't turned back on, incase it doesn't after another 24 Hrs what can i replace to get it going again?
Score 1
Add a comment
Chosen Solution
Here is a link to the cell phone water damage guide. Its for 3G but most of the procedures should be the same. Good luck.
Repairing iPhone Liquid Damage
Score 5
1 Comment:
Cool I ordered the battery and tools to open it. Gonna see what damage was done. hopefully the rice got most of the moisture.
by
Add a comment
Well, you should never, ever try to turn on a water damaged device.
Water itself is not damaging, but it deroutes electricity where it's not supposed to do.
So, at first, you should dismantle your device and clean it throughly with isopropylic alchol. Let the parts dry, then reassemble and evaluate.
You're surely going to need a new battery: yours surely was shorted when it got wet.
After the battery change, you could check for other signs of damage.
iPhone 4S Battery Image
Product
iPhone 4S Battery
$16.99
Score 4
2 Comments:
Thanks I'm gonna give it a shot!
by
Be careful. Keep every small piece handy. You may need the "iPhone Liberation Kit" to remove the pentalobes in the back.
by
Add a comment
The most common problem on the iphone 4S which has been exposed to water is battery failure. With the 3GS it is usually the LCD. Remember that the rice trick is only a temporary solution since moisture can still be trapped inside of the main board shielding. Read more about what to do with a wet cell phone here. As a previous poster said, turning the phone on is a bad idea as it causes electricity to flow through components that are still wet. This can easily short something out and cause more damage. Once you replace the battery pay attention to whether the phone gets hot while charging. This is a good sign that you will have problems in the future.
Add a comment
I replaced the battery and it power on and worked for one day then it wouldnt work again the next day is there anything more i can do
Add a comment
Add your answer
lab308joe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 13,433
