The ninth generation of Chevrolet Impala debuted for the 2006 model year. This generation of Impala was offered as a front wheel drive four door sedan, and was powered by a wide range of V6 engines. Production continued for fleet versions until 2016 under the name "Impala Limited".
Blown head gasket or thrown rod? White smoke, oil from gasket brnt.
Visible burnt oil from gasket seam all around the seam. White smoke exhaust, loss of compression...
1 Comment
@bapland211 what is the exact year, engine size and what type of transmission (AT,MT)?
by
Add a comment
1 Answer
Most Helpful Answer
@bapland211 white smoke from an exhaust is pretty indicative of coolant being burned in the engine. Sounds like a blown head gasket or a cracked head. I would suggest you do a leak down test and see if you can identify, where the compression is leaking from. Also, pull your sparkplugs and look at the faces. With that you can check each cylinder to check to see if some are worse then others.
All the thrown rods I've had came out on the side of the block :-)
Adding images to an existing question
Score 1
Add a comment
Add your answer
Bapland211 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 72
