Model No. A1367 / 8, 16, 32, or 64 GB capacity
1281 Questions View all
Half white half negative LCD
Just replaced my ipod touch 4g cracked screen. Everything works fine, but half the screen is white, and half is negative. Everything works, the digitizer works as well, I can navigate using half the screen, but just the lcd appearance is bad.
Is this a bad LCD or does it sound like I damaged something on the inside?
Add a comment
1 Answer
Chosen Solution
Try opening the iPod up and checking the LCD connections. Maybe part of it is loose and not properly connected. Also make sure the metal contacts are clean and don't have any finger-grease on them.
If this doesn't work, then there is a chance that you accidentally damaged the wiring inside the LCD ribbon, in which case, the LCD has to be replaced. Make sure you don't put pressure or get scratches on any ribbons as they are very delicate and break easily. Damaged ribbons aren't physically obvious to spot until you turn your device on.
Add a comment
Add your answer
Evan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 855
