Crank no spark to coil replaced fuel pump and coil packs
Crank no spark replaced fuel pump and coil packs after being ran empty and sat up for a year
Add a comment
1 Answer
@luda10284 you are really not giving us enough information. It would be great to know the year as well as your engine size. Going by you sparse description of the issue with no spark and no fuel pump activity the issue sounds like a failed crank position sensor. Check and change your sensor and see what you get.
2 Comments:
2012 Hyundai accent gle
Was ran out of gas was told that fuel pump was replaced along with coil packs and battery getting fuel up front don't know engine size it's a small 4 cylinder car just helping out a elderly neighbor when I can ordered two parts crank and cam sensors just in case just trying to cover all my bases
by
@luda10284 i would start by replacing the crank position sensor.
by
Add a comment
Add your answer
Luda will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 211
