I need to replace the display screen of Ipad Air 4 11".
I need to replace the display screen of Ipad Air 4 11". I need to know , what components i needs, where i can find them, plz reply in details. In a min possible.
For iPad Air 4 (11-inch) screen replacement you need:
Part required
Complete LCD + digitizer assembly (laminated together, not sold separately for this model).
Tools required
iOpener or heat gun (for loosening adhesive)
Suction cups and opening picks
Plastic spudger
Pentalobe and Phillips screwdrivers (depending on screws used inside)
ESD-safe tweezers
Adhesive strips (precut adhesive kit for reassembly)
Steps overview
1. Power off device.
2. Apply heat to edges to soften adhesive.
3. Use suction cup + picks to lift screen carefully without damaging Face ID sensor or cables.
4. Disconnect battery first, then display flex cables.
5. Remove broken display.
6. Transfer Face ID sensor assembly if needed (very fragile).
7. Install new display assembly with fresh adhesive.
8. Reconnect battery and test before sealing.
Where to buy parts
iFixit (ifixit.com)
Mobile parts suppliers (e.g. InjuredGadgets, MobileSentrix)
eBay/Amazon (look for OEM or Grade A replacements)
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 110
