Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1954 Questions View all
Installed new battery and charger dock, now no ringer/speakerphone?
I bought a new battery because my old one was going dead within 3-4 hours after a full charge. Right after that I realized it was probably a dock/charger problem, because if I wiggled the internal docking module, it sometimes solved the problem.
So I bought a pre-assembled dock unit from Amazon that was supposed to include a new vibrate/buzzer (it didn't) and tools (they were useless - the iPhone has no Star-headed screws), then I watched the videos on this site and tried to swap both items.
I think the battery worked out OK, although I had to tape it to the logic board to get it in just right.
As soon as I got everything assembled, I noticed I could not use the speakerphone. Then I noticed I could not adjust the sound up or down using the side buttons, unless I'm in "Settings", then they work fine.
Am I right in thinking that my dock unit has a bad speaker?
Or maybe the ribbon connector (#7) has gone bad?
I had a tough time reconnecting #7, #3 and #6, maybe I tore/bent/broke something?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Check the cables is they are all clean, reconnect everything.
If the problem is still there you could have a faulty unit.
If it's not an option to send the unit back to the store, seller where you bought it from then open the two units. just use a screw driver to pry them open. once upen cut the speakers units loose, resolder the connection points with a short piece of wire. This could help.
Add a comment
Add your answer
My BOOMSTICK will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 324
