Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
336 Questions View all
Space key cleaning or rework
Few days ago the space key is not so sensitive. I tried to clean with press air but the result is zero. How can I rework that button without any damage?
Update
As I realized the bottom side of upper case impacted by some water and or oil by the previous owner.
How can I clean that?
Comments:
Is it sticking? Have you spilled anything on it? Do you have children or a girlfriend?
by
No it doesn't stick and as I know nobody spilled anything on it.
by
Add a comment
Chosen Solution
Based on that video http://www.youtube.com/watch?v=IIpgG9fHc...
I just lifted up the space bar adn tried to clean it but the result wasn't enough for me. I think the small rubber cap lost its flexibility. Due to that fact I just used some glue and a small paper square (thickness is 1-2mm only). That small thing has been increased the sensitivity to my expected level :)
Score 1
Add a comment
Most Helpful Answer
An "Apple expert" replaced the battery of my macbook air last week. To fix the new battery there are a lot of screws, but one is just behind the space tab. The person who did it made a mistake and used a screw too long that press the space tab from inside and create a deformation, making the space tab to loose sensitivity. When this key doesn't work writing is the ##$*!
I opened the mac myself following the ifixit instructions, discovered the problem and changed the screw for the correct one: problem solved!
I hate the Mac technical support in Barcelona
I love ifixit
Wish my experience will help someone
Score 1
Comments:
+ nice fix Jorge
by
Add a comment
See Space Bar doesnotworkproperly problem.
If this Answer is helpful please remember to return and mark it Accepted.
Add a comment
Add your answer
William Sawyer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 63
All Time: 3,151
