The Xiaomi Redmi Note 5 Pro is a mid-range smartphone by Xiaomi released February 2018. It has a 5.99" IPS LCD display, a 12 MP main camera, a 4000 mAh battery, a rear-mounted Fingerprint, and runs on a Snapdragon 636.
see the hot battery temperature video quickly
Battery and temperature
1 Comment:
Yasin, this is almost certainly a translation issue, but your question is incomprehensible in English. Please repost your question in your native language, doing so in detail. Exactly what is your phone doing or not doing? Is your battery overheating? How long has it been doing so? What have you tried to do to fix it? The more you explain the problem, the better chance we have of being able to help. If you need to add a picture or video to your question, see this guide which explains how to do that.
Adding images to an existing question
by
Add a comment
1 Answer
@yasinahmad your question is a bit cryptic. From what I understand it heats up or says battery temperature to high. Start off by replacing the battery and then re-evaluate. Since iFixit does not yet have a guide for that, use something like this video Replacement batteries are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Add a comment
Add your answer
Yasin Ahmad will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 4
All Time: 44
