15% Off Selected iFixit Tools — Limited Time
Acer Nitro 5 AN515-58 is the 2022 release of the Acer Nitro 5 series. This guide should be compatible for all the Acer Nitro 5 AN515-58 variant.
My bios is corrupted is there a way to fix it or am I cooked
I was getting driver issues and then i reinstalled my gpu drivers IN safe mode, then i reboot and i went into my bios to check everything and then i left it be after hitting save and exit and now it won’t even turn on as it power cycles every time i try to boot, i believe my bios is corrupted and i don’t know how to fix it as i couldn’t fixed a diagram of the motherboard anywhere (to reset the bios because i couldn’t find the battery anywhere) . Please if someone knows to help that would be amazing
Add a comment
1 Answer
Chosen Solution
Hi @gmode
The RTC battery supply that maintains the BIOS when the laptop is switched off, is supplied by the main battery and not a separate battery on the motherboard.
Disconnect the main battery cable from the motherboard, then press and hold the power button operated for a full 30 seconds and release.
Reconnect the main battery cable, reassemble the laptop, connect the charger and check if it turns on OK etc.
Score 1
1 Comment:
I will give it a shot when i get the chance and i will reply if it worked,
Thank you
by
Add a comment
Add your answer
Gmode will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 28
All Time: 324
