The Acer TravelMate X349 is a business laptop made by Acer. This page contains repair and service information related to the Acer TravelMate X349.
My laptop not charging
Laptop not charging
Add a comment
1 Answer
@vin82308 first you want to check your power supply. Make sure it has the proper voltage. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out.
If none of this works, get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. Adding images to an existing question - iFixit Repair Guide
Add a comment
Add your answer
vin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 32
All Time: 119
