Shop the Holiday Gift Guide
language:Chinese 笔记本底盖打不开 English: The bottom cover of my notebook won
See image content:
Add a comment
1 Answer
Most Helpful Answer
Hi @ncha66111
Check if the battery is swelling and causing the case to come apart.
Here's the hardware maintenance manual for the laptop.
Go to p.35 (39 of 95 pdf) in the manual, to view the procedure how to remove the battery.
If the battery is swollen it will need to be replaced. Go to Item #12 on p.79→p.80 (83 →84 of 95 pdf) in the manual to find the part numbers for the batteries that are compatible with your particular laptop. Search online for the applicable part number to find suppliers that suit you best. The part number should also be shown on the battery in the laptop, if you wish to verify.
Remember to dispose of the old battery responsibly. The environment will thank you for doing this.
Score 2
Add a comment
Add your answer
NCHA will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 20
All Time: 164
