Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
19981 Questions View all
exhaust fan works at 4505 rpm,should I be concerned?
Ambient temperature in india where i live soots up 42celsius and the minimum is 28celsius,i do not use an airconditioner
following are the temperatures recorded at the moment
HD MAC 39,CPU73,ENCLOSURE BASE 39,ENC BASE2 39,ENC BASE337,ENC BASE 4 41,METASINK 62,NORTH BRIDGE 54
FAN RPM 4137
Score -1
Add a comment
1 Answer
Chosen Solution
I would go in and clean out the fans and the exhaust ports and re-apply thermal paste and see if that drops your temps.
Score 2
3 Comments:
Is there any cleaning liquid I should use and the thermal paste preferably the brand name or can i blow it over.Thermal paste application is it a complicated one .Thank you sir I am obliged
by
According to which Book you have, yes changing thermal paste is not easy or quick, but it really is if you've gotten it open far enough to clean the vent ports ;-), you didn't ask about easy. I use Arctic Silver #5, available from iFixit. [linked product missing or disabled: IF179-010]
by
Thank you sir,i will buy the paste from i fix it then complete it and report back to you,i will go through the instruction which appear in the sight and shall seek your advice later,once again many thanks
by
Add a comment
Add your answer
NARAYANAN LAKSHMANAN will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 452
