A more affordable, purely handheld version of the Nintendo Switch game console, with integrated Joy-Con controllers and a slightly smaller screen. Released September 20, 2019.
I put new joysticks in but have no display and can't find a problem
Replaced joystick but now no display. Sound and touch are working fine. And the screen worked fine before the new joysticks.
Score 1
1 Comment
I am hoping I just have a cable slight off my I can't tell and that someone else will notice it because to me it looks like their all in fully
by
Add a comment
Most Helpful Answer
Hi!
First, take the display ribbon cable out and check for damage. Also check the port. If all of them are OK, you might want to replace the display and just test if it is working or not. Otherwise it will be very difficult to tell what it is..
Score 1
4 Comments:
Ok thank you I will try that
by
Alright! Please keep us posted! Thanks!
by
Don't see any damage I am just going to buy my sister a new switch because it's cheaper rn then getting the screen replaced
by
Hi! Alright, it's most likely the display that is broken, or something on the motherboard. Difficult to say without testing the part, sorry! If you have any questions, please let me know!
by
Add a comment
Hey,
I personally haven't experienced this problem however, a similar problem I've had: I pulled apart an xbox controller and when I put it together again it worked fine as long as I was close to the console. The further away I got from the console, the more problems I had.
I pulled apart the controller again and found I hadn't reconnected one of the antenna wires.
Relating to my issue, I'm just wondering if you have possibility forgotten to plug something back in, reconnect a ribbon cable or something.
1 Comment:
No everything is in I have rechecked everything 4 times but thank you
by
Add a comment
If replacing the joysticks left you with no display, double-check all ribbon cable connections, ensure nothing is pinched or misaligned, and test with the battery reseated before suspecting a hardware fault.
1 Comment:
Yeah have removed everything and put it back ten time now so I give up but thanks for trying to help everyone
by
Add a comment
Add your answer
Izaya Morningstar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 20
All Time: 128
