Repair, disassembly, and troubleshooting information for the Xbox Series S, Microsoft's newest small form factor, digital-only gaming console. The Xbox Series S was released alongside its more powerful big brother, the Xbox Series X, on November 10th, 2020.
xbox not turn on but power supply is working
my xbox series s not turn on but when we connect cable to my remote then i know power sypply is working what that problem
Score 1
Add a comment
1 Answer
1. Check the Power Supply (for Xbox One with external brick)
  • Make sure the light on the power brick is solid white or orange.
    • No light? → The power supply is dead → replace it.
    • Blinking light? → Fault in the power supply → unplug for 10 minutes, then try again.
2. Power Reset
  • Xbox One / Series X|S:
    1. Unplug the power cord from the console.
    2. Wait at least 10 seconds (better 30–60 seconds).
    3. Plug it back in and press the power button.
  • If still nothing, try plugging directly into a different wall socket (no surge protector).
3. Check HDMI & Display
Sometimes the console is on but no display:
  • Make sure the HDMI is connected to the HDMI OUT port, not HDMI IN.
  • Test with another cable and TV.
  • Try holding the power button for 10 seconds until it fully shuts down, then power it back on.
4. Eject Button Power-On Trick (Xbox One Only)
  • Press and hold the eject button + power button together until you hear a beep.
    • If it turns on, the power button might be faulty.
5. Overheating / Dust Issues
  • If the console overheated, it may refuse to power on until cooled.
  • Clean vents and make sure it’s in a well-ventilated area.
6. Internal Hardware Issues
If none of the above works:
  • Possible issues: bad power button, motherboard, or internal PSU (on Xbox One S/X and Series X|S).
  • At this point, you may need repair or replacement from Microsoft or a local console repair shop.
Update (08/22/25)
2. Power Reset
Add a comment
Add your answer
ujjwal badoni will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 47
All Time: 533
