Memory 4 GB from 2 GB
Hello,
Thank you.
Last 3 digits in my serial no. is F8X
Where should I buy 4 GB memory?
Sincerely,
Flemming
Hello,
Thank you.
Sincerely,
Flemming
Anyplace you'd like. Here, ebay, google shopping. As long as you get the right speed and pins your good. It helps tostart with IDing your Mac.
If this Answer is helpful please remember to return and mark it Accepted.
Your machine is a :
Apple MacBook Pro "Core i7" 2.2 15" Early 2011 Specs
Identifiers: Early 2011 15" - MC723LL/A - MacBookPro8,2 - A1286 - 2353-1*
It came with: Standard RAM: 4 GB Maximum RAM: 16 GB*
Details: 4 GB of RAM is installed as two 2 GB modules, no slots free.
*Apple officially supports a maximum of 8 GB of RAM, but this model actually is capable of using up to 16 GB of RAM with two 8 GB memory modules. Supports 1333 MHz PC3-10600 DDR3 SDRAM.
The largest pure SSD drive that I am aware of as of this writing that will work in your machine is 512 GB Crucial :
Here's how to install the RAM: MacBook Pro 15" Unibody Mid 2010 RAM Replacement
Here's how to install the hard drive: MacBook Pro 15" Unibody Mid 2010 Hard Drive Replacement
I don't even think a 1 TB SSD exists for that size. The only 1 TB SSD that I think exists is the OCZ 3.5" drive, but that wouldn't fit into a MacBook Pro. That alone, in the bigger size, costs over $2500. The largest one that I have seen for your computer is 512GB in capacity. I recommend these solid state drives from amazon:
http://www.amazon.com/dp/B004W2JL3Y/ref=...
If you give me the last 3 digits of your serial number I can tell you where to buy ram.
Hope this helps.
Here is the link to the 8 GB of ram that I recommend:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 386
