The Aspire 3 A315 is a repairable laptop by Acer.
Acer Aspire 3 15 wont turn on, all lights off
Hi,
My Acer is not turning on at all. I tried leaving it charging for a while but nothing. I tried the reset battery button and holding the power button and it didn't work.
The little light indicator next to the battery is not turning on. I tried using the usb-c port with a charger that is confirmed to be working and nothing.
Last time I used it I turned it off normally and put it away.
Is there anything I can do?
5 Comments
Hi @d1300
What is the full model number of the laptop as shown on the product information label on the bottom of the laptop?
by
Hi
It's an acer aspire 3 15 model N23C3
by
@d1300
Just verifying that you tried using a charger connected to the DC charge port and also a USB-C charger to the USB-C port and neither worked, is this correct?
by
Yes, didn't work
by
Thanks for all the help
I reconnected the battery and noticed that I inserted the connector more deeply (didn't force it though) than it originally was when I opened the computer. Maybe something happened to make it a bit loose, don't know, all I know is that it's all working now.
Thanks for all the help!
by
Add a comment
Most Helpful Answer
Hi @d1300
How long since it was last used? If a long time I wonder if the battery is totally discharged. Perhaps try leaving a charger connected for 3-4 hours and check if it shows signs of life
It still no good, it seems like there may be a problem with the power management circuit on the motherboard as both power inputs ports (DC-IN and USB-C) aren't working.
If the motherboard model number is DA0ZAVMB8E0 here are the schematics, a link to the boardview file (you need to have a program that opens .cad files) and a video that shows how to open the laptop, that may help to find out what's wrong.
The power management circuit is on p.23 of the schematic
Score 1
1 Comment:
Hi
It was used last Thursday and it worked great. Turner it off, didn't use during the weekend.
I'll have a look, thanks for providing some info and guidance 😊
by
Add a comment
It sounds like a power delivery issue—try a different charger/power outlet, check for a faulty DC jack, or remove the battery and hold power for 60 seconds before reconnecting.
Score 1
1 Comment:
I took the battery out and connected the charger, and the computer actually turned on.
The battery looks OK though, not bloated at all.
by
Add a comment
Add your answer
d1300 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 54
All Time: 387
